I have bought 45 of those black littokala cells.
All cells had the same voltage when they arrived so that was good.
Did a quick test on my ownboard esk8, made a quick 10S1P pack.
Esc pulls max 18A so perfect to see how these perform and they worked great actually so no fake stuff.
If they were fake they couldn’t be able to cruise for 10km so I know for sure they real.
I could do some more km but after 10km and going full throttle the remote started vibrating so it means the voltage drops below 32V.
Voltage after 10km was still 37V so that’s just how the battery should perform if you check them on lygte.
They perform as good as the samsung 30Q.
You can see with a 10S1P setup you only get around 3Ah ‘real’ capacity.
A 10S2P will be perfect for those ownboard/wowgo/meepo esc’s.
Your packs will have more discharge so that’s normal. This was just a test pack, I won’t never use a 10S1P with 18650 or 26850 cells
did some more calculations again to be sure my memory wasnt wrong.
The 21700 beats 26650 in every metric if you compare for example 10s3p to 10s3p.
1kg lighter, almost half the price and half the space needed, so you could increase the p count for the 21700 and still be lighter and have the same mAh/amps possible.
I am rly excited to test this.
well you can’t rly beat the 30Q. The liitoKala lose in weight and space against the 30Q, but you pay extra for that performance. that is what it boils down to basicly.
10s3p
21700 vs 30Q . 30Q needs 31% less space and 25% less weight but is 25% more expensive and has also 33% less capacity.
26650 vs 30Q. 30Q needs 212% less space and is 200% lighter, 66% lower capacity but 8% cheaper.
TLDR I remember again why i choose the 30Q instead of these. What you save in money once, you pay everday by having a heavier and bigger battery, you could just go 1 or 2 p up to get the same capacity and still be lighter and even have a higher Amp potential. BUY 30Q.
Edit: My calculation is based around that i don’t pay import fees, so i need to buy smaller packages, more expensive.
Edit2: Had to correct some mistakes.
Yeah that’s true VCT6 30Q and 40T are just the best but you pay for it.
If you wanna try a cheaper alternative I think the Littokala 26650 and 21700 are just pretty good choices to try, if you make sure to look at their tested max current
Those 2 types can do around 15A - 20A so that will be safe for these.
