Apparently they’re spotty. Mine blew after less than 30 miles. Focbox in the mail!
Hi guys, i have an issue where the belt will tend to rub on the wheel. Any way to fix it so there’s some leeway? Or should i get another pulley with a flange?
Nudge the motor mount to the side a bit
Mine came loose when riding for the first time, after applying threadlocker too. A C clamp would be better than four set screws holding to the truck i feel.
Did you install it how @Deckoz does? Using an Allen socket and tightening the back bolts first.
Tutorial is in here.
I used his method and so far it’s good. Only been able to ride 20km but it seems solid now…
I see, i used a long allen key with a plastic handle so i figured that’ll be enough torque to tighten the clamp. Perhaps i’ll try it again when i build a new board!
Thank you! There’s about 1mm of clearance now. I used three ice cream sticks as spacers.
But now as the mount is closer in the middle, the bearings for the idlers do not wrap the belt fully, extra washers for the bearings to stick out is my next to do list.
Bro put a speedring between the bearings! Two bearings rubbing up against each other is not good in any case. They are never perfectly aligned and that causes unnecessary friction. I also recommend you get a top M4 washer that is a little bigger and while youre at it put 1-2 underneath. Problem with your spacing solved.
Your motor pulley kinda looks like a 15mm pulley?
Yep it’s a 15mm pulley, however i’m using a 12mm belt. So how should the sequence of the bearing and washers go? Bolt/washer/bearing/washer/bearing/washers?
I bought some washers with 4,5mm inner, 12mm outer diameter and some normal Skate “Truck axle washers” aka Speed rings Your sequence is correct. Bolt, washer, bearing, speed ring, washer/s, mount, locknut Make sure your bolt is still long enough to go through the complete nylon locking on the nut. Apply lots of loctite.
Does anyone know where to get nylon spacers for the idlers - 4mm inner, 8mm outer diameter? The ones that come with the mount don’t fit perfectly plus I want to be able to replace them.
yeah same. I think if he knew where to get any, he would use it.
Hey guys, The nylon spacers are custom cut to length from a stock nylon tubing I got from a specialized local hardware store near my home. They are #8 x 5/16" tubing.
Nice! Using large surface washers can protect the bearings from debris too. I might change my bearings to something more rust resistant as it’s starting to show signs of corrosion, and i’ve not even started riding it yet haha
Guys, i have a problem. I’m trying to run sensored but i can’t seem to wrap my head around it. I’m using the VESC tool version by @Ackmaniac, and used the motor wizard set up.
I was able to set one up, but when running a motor detection for the other motor, it ran for just a split second and then disconnected from the computer. I tried it a couple times and decided not to do it anymore less i risk blowing something up (that’s what my paranoid ass would imagine in my head)
If it is for bldc the set the duty cycle to 0.15 for the detection and use the normal detection and not the wizzard.
