i like the triangle ones too. And don’t forget the pentalobes.
You won’t regret your decision. Ever. As long as you have quality torx bits (bits in swedish)
Made the small ones here out of 1/4" drive 4 and 5 mm sockets, and a piece of hex key hot glued in a 6pt socket.
They have been cut down further as they were worn.
Just use a long enough piece when you do it to allow trimming it when it wears.
It’s almost impossible to loosen or torque down a fastener with an L wrench without putting a side load on the tool/screw.
Edit: I guess I mean it’s hard to squarely apply torque with an L key.
I like my motion pro 1/4" drive T handle.
Stripping a holt makes the indent of the hex/torx bigger. Hence, using a bigger bit/torx/hex will fit into it. How long that will last? Not very long.
