Hi all,
Ive been trying to get smoother braking on my 4wd board with out much success.
Braking from high speed works well but once the board has slowed down to about 5 mph, the braking force increases abruptly.
Ive increased and decreased motor braking vs regen and havent been able to get rid of the issue.
Ideas?
Brake settings:
Motor min: 30A
Regen: 12A
Have you try @Ackmaniac software… because it can give you the opportunities tu create a special curve for you brake or acceleration.
Guess you are using BLDC mode.
Set this value to 500 and try it again.
So my firmware doesn’t really make a change here. But with my firmware you could set up different acceleration and brake power for the front and rear axle. Let me know if you are interested. Need a test guinea pig because i don’t have a 4WD (yet ).
I havent tried yours actually but would love to. Sign me up please!
I will give the brake erpm settings a try and report back. Thanks
@JohnnyMeduse thank you.
