Hi,
I was about to finish my build and spun the motor at full throttle without load, than it suddenly stopped.
The BLDC tool gave me the fault code DRV8302. This is the controller chip.
Is the Controller dead now?
I’m at a uni and can infrared solder it myself. The question is if the DRV is REALLY the issue and how that issue started. I never even use the board on the ground.
If the red led flashes three times on the VESC when you use the throttle then it is a DRV error. I would still talk to @JohnnyMeduse and he can help you diagnose your problem even if you don’t want him to fix it.
That MIGHT be the only thing toast but it is possible a lot of other components are toast as well on the board. Did you go directly from neutral to full throttle? The key to not killing the vesc(without load) is gradually easing into full throttle when on the bench. Going directly into full delivers too many amps at once and fries the drv and maybe other things. On bench, the motor is able to go to full speed in about 20-30% of throttle as opposed to the full range when under load.
Bottom line: DRV is definitely toast, Inspect other components, Ease into throttle next time.
I did measure it all through, but thanks for the hint! I’m using Torque board HUBs, maybe thats why the values look different?
I’m running dual motor setup and the other controller is luckily fine. I just had my first test ride and had super low torque, I drove like 3km/h.
Back on the bench am I able to hold the wheel with my bare hands (and not too much effort). Battery amps stay low, motor amps go up high, but there is no real torque. Any clue why?
I switched to FOC because with BLDC did the tool not find the hall sensors.
Can you give me some insight on why not to use FOC except this full throttle without load thing?
I mean you can, a lot of people run it. I know @mmaner has hundreds of miles on his. You just need ackmaniac firmware and a gentle curve to limit input of amps into vesc.
Looking at his values I don’t think he studied enough about the bldc tool to use it TBH.
@nordlicht try @Ackmaniac VESC tool. It has wizards that can guide you through all you have to set up to get it working. Also study study study. 9h read time is actually quite low.
WHat do you mean by motor detection? detection of the parameters for FOC and hall sensor detection? yes I did, or do you talk about something different?
i remember that between the help on here and myself, I wouldnt allow myself to change anything on the vesc until I had watched that long vesc setup tutorial and read
