Any idea how thick nickel strip they use in these batteries? And can ask for them to add second layer of nickle strip?
Yeah I think we need a little more informations about the batteries, buying batteries is always scary, especially if they’re from unknown Chinese manufacturers (plus have you found out if it has a switch and if a led voltmeter could be added? ). Also, have you checked the dimensions of the trucks to see if they fit normal caliber mounts? I know @fedestanco had some problems
Thanks for your work
I’ll answe all these questions when I get home
But I don’t think there’s any problems
0.3MM 2 Layer
Hello
I’m in for
- 1 set of 90mm wheels (black)
- 1 pair of trucks
- 1 mini controller+receiver
Interested also in
- 6374 190kv motor
- pulley and belt (12 or 15mm)
- wheel pulley
Hi, I would like to cancel the trucks and pulley. So I’ll just be getting the following:
10s3p battery
charger for the battery
benchwheel remote
Thanks and sorry for changing it last minute, I hope it doesn’t cause a major inconvenience
Its fine we have about a week before i order
Btw are the anti-spark switch not in the group buy anymore? I put it down earlier but I don’t see it in the table
My bad ill add another column
I’m down for 2 VESCs too! Thanks!
Ok great, put me down for 1 anti-spark switch as well please. Thanks
Why the motor ?
Update. Orange 90mm wheels, trucks, battery 10s4p bms and charger, anti spark switch, 1 vesc, left motor mount, mini remote and maybe 1 6374 motor depending on the price.
Brill - thanks for your work on this @ajaynagra - I think you have missed a pulley set off for me (14/36T or is this not available?) and happy with a steeze remote provided price is ok. Shall I keep an eye on the listing at the top for motor/steeze prices?
Hey sorry to change my order again but could you put me back on for the pulleys and trucks? The person I was gonna buy those off of just pulled out. Sorry about the constant change.
Also sorry I forgot to ask but interested in a charger but I am building my own battery and for now am not going to include a BMS (al la @whitepony ) - Do the charges have 42v cutoff? and I assume the VESC has a low voltage cut off?
What are the specifications on the pulley kit? Such as width (9mm, 12mm…), what’s included (motor pulley, wheel pulley, belt), and what motor axle size can fit…etc
Thanks
9MM flywheels includes motor pulley 36t/16t and 265m htd5 9mm belt 9MM kegels includes motor pulley 36t/16t and 265m htd5 9mm belt
Ok so if I were to get just the pulleys and belt it would be 9mm?
