Btw are the anti-spark switch not in the group buy anymore? I put it down earlier but I don’t see it in the table
My bad ill add another column
I’m down for 2 VESCs too! Thanks!
Ok great, put me down for 1 anti-spark switch as well please. Thanks
Why the motor ?
Update. Orange 90mm wheels, trucks, battery 10s4p bms and charger, anti spark switch, 1 vesc, left motor mount, mini remote and maybe 1 6374 motor depending on the price.
Brill - thanks for your work on this @ajaynagra - I think you have missed a pulley set off for me (14/36T or is this not available?) and happy with a steeze remote provided price is ok. Shall I keep an eye on the listing at the top for motor/steeze prices?
Hey sorry to change my order again but could you put me back on for the pulleys and trucks? The person I was gonna buy those off of just pulled out. Sorry about the constant change.
Also sorry I forgot to ask but interested in a charger but I am building my own battery and for now am not going to include a BMS (al la @whitepony ) - Do the charges have 42v cutoff? and I assume the VESC has a low voltage cut off?
What are the specifications on the pulley kit? Such as width (9mm, 12mm…), what’s included (motor pulley, wheel pulley, belt), and what motor axle size can fit…etc
Thanks
9MM flywheels includes motor pulley 36t/16t and 265m htd5 9mm belt 9MM kegels includes motor pulley 36t/16t and 265m htd5 9mm belt
Ok so if I were to get just the pulleys and belt it would be 9mm?
Wheel pulley and motor pulley are 9MM wide.
36T on the wheel pulley and motor pulley 16T
265MM long 9MM wide
But i can do 12MM versions aswell
Ok, for my pulleys, I would like to get the 12mm version please, thank you
Sign me up for 90mm! (not 83mm). Merci
Is it possible to get extra belts in case they break?
I also want 12mm pulley and belt.
Yes i will be sending 3 belts for each pack
Made a revision to the battery pack cost:
Its a bit more expensive now because i wanted to use a better BMS, also added costs for charger
@ajaynagra Is the wheel pulley for Kegels or is there also one for the wheels that you are selling now?
