Hey
so I finished my build with some modifications to the original post. For the battery I used two Turnigy 5S1P 1300mAh Graphene Lipos in series and and bought a complete VESC 4.12.
I did the motor measurements with a 15V power supply some time ago before I got the battery so I plugged in a rc remote for testing and spun the motors after setting up the remote. After spinning them for 10s without any load I tried it again and it didn´t work. DRV8302 fault
Any important settings to make the VESC work with my new DRV chip and 10S 245kv setup?
Here is what i found out, for first turning up u need 12v not 15v or 3s batt.
motor detection, u need to connect the battery u will use. different amp and voltage result different values on motor. which can drv fault happens.
and I dont know which 4.12 u use but if it’s firmware 2.18 it may has current ramping bug under advance section. default is 0.04 if goes over like 0.4 it can fry it too.
