That and it’s away from direct splashes and debris
I would be interested in this
it works well.
so you can put the trucks through the board? I also had another question about the 9 inch AT Truck Kit. Can you mount 6365 motors on it or would it have to be only 50mm diameter? http://www.diyeboard.com/9-off-road-all-terrian-electric-skateboard-truck-kit-p-623.html
Drop-through as in what evolve does where the bottom of the trucks go on the topside of the deck.
we can do it if you provide us the drop deck, if you do it by yourself you need to remounting the motor mount lower to keep the clearance from the deck. and we cupport 6354 6374 6365 motors by need two cnc thick washer to make the motor mount fit in well. see photo,
anyway we focus on regular kit, if you need it we can customize for you but need extra fee per your specific requirement.
Yeah. Thx for the reply. They are great products!
Is there an option to add a battery meter to your 10s3p battery?
you can diy by yiurself, or you can order our esc we sent you a babttery meter that can be plug into our esc and connect the battery.
Its also very easy to connect a meter directly to the battery. I did and I’m happy to help you with guidance if you like.
Should see my pants after riding the splashes are more directed upwards than towards where the motor mount is located.
Good example
Working on clip-on covers for the motors. During summer I would never use them/inhibits airflow.
we have recently improved our pulley gear ratio 36T 12T to 35T 13T, pulley material improved and good thing is our dual belt kit now with speed improved 2-3km/h based on previous 40km/h. now our dual belt kit can reach 42-43km/h now. i make update here so our customers can buy this new pulley kit to upgrade the speed if they need. http://www.diyeboard.com/8352mm-longboard-pu-wheels-with-dual-35t-5m-wheel-pulley-2belts-p-607.html
http://www.diyeboard.com/10s2p-battery-esc-dual-motor-belt-drive-power-truck-kit-8352-p-611.html http://www.diyeboard.com/10s5p-360wh-battery-esc-dual-motor-belt-drive-power-truck-kit-p-590.html
Hello everyone, if you saw my post, please help me do a simple survey here: We noticed 12s is kind of trend now and many builders prefer to use 12S battery, we are planning on 12s battery with 30Q cells and new esc for 12S 48V. We’d like to know your proffessional ideas and advices of 12S battery and 12s esc need and expectations, 12s3p or 12s4p? which is better?
Depends on how much current the esc pulls, and the more"p" you add with 30Q cells it will increase range, also make the board bit heavy, if esc pulls like 40-50A , 12s3p should be enough
thanks, do you think 12S really necessary? since 10s can reach speed 40km why still need 12s?
Completely depends on personal use, it not only depends on the maximum speed, but also the initial torque and after getting comfortable with those speeds some people might want to go faster or while climbing slopes, that extra voltage helps
so this means we need to upgrade all parts, better motor, better battery cells and better esc, and call electronics and cables need to upgrade, so much work and so much pressure on material stock,
Not necessarily upgrade everything “existing” 10s works just fine and I guess people don’t have any problem with 10s setup, its just as a upgrade factor which would be nice if it existed with your escs, better Motors are always a good thing to upgrade.
I think 10s4p 30Q would be enough for most applications. Most esk8´s use a 10s battery.
Topspeed i think 45km/h is enough for most people.
