I used the cola can to protect motor bottom.
I have to say, I haven’t seen that before! I love seeing stuff like this, something different
On a side note, you motor mount in on backwards, is flip it around.
Yes the mount is on backwards but the bolts are oriented correctly with the nut facing towards the kingpin
Other than that, pretty cool. Does it wobble?
I did it on purpose. Because my pulley set screw position. You can check the pulley size. Normal motor mount cannot fit this pulley
The cola can is so light. Cover Wobble don’t matter.
This is genius. You think there would be enough air flow?
