Why not get a fuse holder?. Fuses trip by heat, so I imagine putting a soldering iron to it may trip the fuse if heated up for too long.
Yeah like @Jinra said definelty get a fuse holder, I got some cheap one at AutoZone that works really well for a different project of mine. Also I think an 80A fuse might be a little overkill, I think a 50-60A would work just fine. Oh and with fuses voltage definelty doesn’t matter as long as your not exceeding it by a ton, what matters is amperage, that’s why people like using 12S2P for example not 6S6P because they need less current from the higher voltage battery.
Maybe this could help with the water resistance
Good point @Jinra and @JdogAwesome I will check autozone for a fuse holder.
Also will try neverwet for the pcb in whatever remote I get. As for the board, I would like to seal it off completely because I don’t want to take the heat shrink off my vesc and spray it.
Get an enclosure for your VESC and use SikaFlex (from auto store) to seal up any possible water issues
Update: I just hooked up the sensors on my OM5065 to the Vesc. There is definitely less cogging when I hold the motor still with my hand on my desk.
The only major parts I need to buy now are a remote and a BMS. Having trouble finding a BMS for 10s LiFe.
I plan on milling my own motor mount for the caliper trucks. I want it to be completely adjustable so I can change pulley sizes and bring it closer to the deck if I add bigger risers, so this is what I designed:
<img src=“https://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/original/2X/e/ea540483543c7904089502b3e5e91121f8d474a6.jpg” width=“386” height=“500”How about this one http://www.bestechpower.com/32v10spcmbmspcbforlifepo4batterypack/BMS-D270.html
That mount looks pretty swanky. Torqueboard’s mount looks pretty good as well if you’re considering a commercial one.
That one looks like it will work thanks! Just emailed them asking for the price.
I checked Autozone for a fuse holder and I only found ones for the smaller fuses so I gave soldering a shot and it worked surprisingly well. My system still works and it still doesn’t trip under load (my hand stopping the motor)
Cool! glad it worked out. Seems like it should work fine as long as your fast when soldering. You can get the fuse holder I linked above on amazon for the future, though with an 80A fuse, I doubt you’ll ever blow it.
I’ve been emailing back and forth with BesTech and this is the BMS we ended up on. Wanted to post it here before I buy it so I can make sure there are no problems with it. It has a really low discharge rate because I won’t be discharging through it, this kept it really small.
So after discovering how hard it will be to get somebody to mill my motor mount/help me mill it, I have decided to buy the one @Jinra recommended: link
Should I get the one designed for 50 mm motors or 63 mm motors? @torqueboards I have a 50mm OM5065, but I have seen 50 mm motors with smaller bolt spacing. My motor bolt spacing is about 38 mm or 27 mm depending on how you measure.
His mount does not fit chaka’s motors FYI. He’s working on getting one that does, but it currently will not fit. I’m using Enertion’s mount right now and it fits perfectly.
@ndwallick - what @jinra said. @chaka is difficult wanted to use some odd motor mount spacing
I do have some v3 motor mounts which will fit Chaka’s mount but the latest v4 motor mount doesn’t.
hhhmmm good thing i didn’t buy the 50 mm one yet haha. How much for a V3 mount? also what do they look like? Can I see some pictures? @torqueboards
In my opinion the enertion mount is best for chaka’s motors at the moment but… cause u asked here the v3 mount. BANG!
I love my v4 mount tho!
Besides sealing the deck so it’s waterproof, have you thought of a way to keep your bearings dry? I know a lot of heavy grease would help. Maybe a hub cab like some of the hub motors have, but without a hole in the center.
@jrpwit Oh yaaaa I remember seeing that mount before. Looks like the V4 is a big improvement. I wish it worked with my motor. It looks like the Enertion mount would be the best for me, but the blue will throw off my color scheme. Maybe I can paint it.
@Mrmoonlight I’ve solved that problem with these ceramic bearings.
Nice, what are the races made out of? Aluminum? Stainless? Might have to get me a set.
Not sure, I just know they are know for working well with water. I’m curious too now what the rails are made of, guessing stainless.
