I am starting my second build and I thought I would post all my progress here.
goals for this build:
entirely waterproof, I want to be able to ride it through pouring rain and puddles (anyone have tips for waterproofing?)
easy to charge, I want a BMS on board that allows for a 2 wire charger
better ground clearance than my last board
remote that doesnât try to kill me when it looses connection:
Heres what I have so far:
Arbor snowboard style deck
Calliper trucks
Kegel Wheels
Ceramic bearings
Pulley from DIY Electric skateboard
Vesc from Ollin Board Company
170 KV motor from Ollin Board Company
LiFe batteries from Hobby King (5 2s batteries)
Build sounds awesome and thatâs a beautiful deck you got there! I donât have many tips of waterproofing other than, THATS A GREAT IDEA cause Iâve had numerous problems with water corroding contacts and messing with other things.
I just bought this fuse today from autozone, its 80 amps and it says its rated for 32 volts, but I read numerous things online that said they will work with higher voltages (I will have a max of 36 volts)
Has anybody tried these fuses, I will probably solder the blades to a connector to attach it.
Yeah like @Jinra said definelty get a fuse holder, I got some cheap one at AutoZone that works really well for a different project of mine. Also I think an 80A fuse might be a little overkill, I think a 50-60A would work just fine. Oh and with fuses voltage definelty doesnât matter as long as your not exceeding it by a ton, what matters is amperage, thatâs why people like using 12S2P for example not 6S6P because they need less current from the higher voltage battery.
Good point @Jinra and @JdogAwesome I will check autozone for a fuse holder.
Also will try neverwet for the pcb in whatever remote I get. As for the board, I would like to seal it off completely because I donât want to take the heat shrink off my vesc and spray it.
Update:
I just hooked up the sensors on my OM5065 to the Vesc. There is definitely less cogging when I hold the motor still with my hand on my desk.
The only major parts I need to buy now are a remote and a BMS.
Having trouble finding a BMS for 10s LiFe.
I plan on milling my own motor mount for the caliper trucks. I want it to be completely adjustable so I can change pulley sizes and bring it closer to the deck if I add bigger risers, so this is what I designed:
That one looks like it will work thanks! Just emailed them asking for the price.
I checked Autozone for a fuse holder and I only found ones for the smaller fuses so I gave soldering a shot and it worked surprisingly well. My system still works and it still doesnât trip under load (my hand stopping the motor)
Cool! glad it worked out. Seems like it should work fine as long as your fast when soldering. You can get the fuse holder I linked above on amazon for the future, though with an 80A fuse, I doubt youâll ever blow it.
Iâve been emailing back and forth with BesTech and this is the BMS we ended up on. Wanted to post it here before I buy it so I can make sure there are no problems with it. It has a really low discharge rate because I wonât be discharging through it, this kept it really small.
So after discovering how hard it will be to get somebody to mill my motor mount/help me mill it, I have decided to buy the one @Jinra recommended: link
Should I get the one designed for 50 mm motors or 63 mm motors? @torqueboards
I have a 50mm OM5065, but I have seen 50 mm motors with smaller bolt spacing. My motor bolt spacing is about 38 mm or 27 mm depending on how you measure.
His mount does not fit chakaâs motors FYI. Heâs working on getting one that does, but it currently will not fit. Iâm using Enertionâs mount right now and it fits perfectly.
Besides sealing the deck so itâs waterproof, have you thought of a way to keep your bearings dry? I know a lot of heavy grease would help. Maybe a hub cab like some of the hub motors have, but without a hole in the center.
