Predator uses the same one Maybe @PredatorBoards could tell us where to get it But its probably secret, am I right?
EDIT: They are bought from Winboard Still I am interested if it were possbile to buy just a piece somewhere
they donβt have independent receivers. the receivers are soldered on to the custom escs.
Unfortunately this is the sad case. Itβs all proprietary stuff.
Thanks for help
They make connection between ESC and BMSβ¦this way they communicate together, which is also the reason, why you cant use ESC separablyβ¦
IDK why, boosted probably ensure that it cant by moded, it might have some advantages
@Martinscce did you figure out how to replicate the CAN h/l data for your board to work again?
For others, is there a range of voltage accepted by the esc? Iβm guessing yes, since they take on the extended packs without issues.
Hi do you still have your BB V1 ESC if so would you be willing to sell it?
I got the same problem iv tryd connecting diff voltages to those 2 small cables 3v,12v even the full 40v from the batteries .remote connects to the board but it indicated low battery and does not start the motors
