First build here. Very appreciative of the the community here. The info found throughout helped me navigate through the build.
Board
Loaded Vanguard Flex 2 Caliber II Trucks 100mm MBS All-Terrain Wheels 1/8" Shock Pads
Enclosures
@psychotiller Custom Split Enclosures 1/8" Neoprene Padding EZLOK M4 .7 Inserts for Mounting M4*16 Bolts
10s3p Battery
30x LG HG2 18650 Batteries (3.7V 3000mAh) 3/8 Copper Grounding Strap/Braid (40A rated) 10AWG Silicone Wire (30A rated) 18650 Battery Insulators
Battery Management
42V 60A BMS System (Charge Only) 100A 58V Fuse 5.5x2.1mm DC Power Female Jack Socket 42V 2A 5.5x2.1mm Power Supply Battery Capacity Tester Status Indicator BI665 Heat Shrink 180mm for 10s3p Heat Shrink 85mm for BMS 1x XT90 Parallel Connector for splitting power to VESCs 1x XT90S for AntiSpark Key/Switch Bullet Connectors XT90 Connectors
Electronics
2x TORQUE 190kv 6355 Brushless Motors 2x TORQUE 36T ABEC Pulley Combo Kit (36T ABEC Drive Wheel Pulley :16T Motor Pulley : 265mm belt (12mm width)) Will be switching to 40T/16T with 275mm belts - Too much voltage sag up hills @ 205lbs 2x TORQUE Motor Mounts 2x TORQUE ESC VESC 1x CanBus connector 2x VESC Sensor Wires 1x Male to Male Servo Connector Nano 2.4GhZ RC Controller HM-10 Bluetooth Module (for iOS App Live Stats)
VESC Settings
Ackmaniac Custom Firmware 2.54 Ackmaniac Custom BLDC Tool for Mac CAN link
Master: Motor Max: 80A Motor Min: -60A Batt Max: 30A Batt Min: -6A Battery Cutoff Start: 32V Battery Cutoff End 30V Slow Absolute Max Use Max Watt (800 watt) … Adjust for how im feeling
Controller ID: 0 PPM and UART
Watt no reverse with brake Safe Start Multiple ESCs over CAN Enable Traction Control
Slave Motor Max: 80A Motor Min: -60A Batt Max: 30A Batt Min: -6A Battery Cutoff Start: 32V Battery Cutoff End 30V Slow Absolute Max Use Max Watt (800 watt) … Adjust for how im feeling
Controller ID: 1 No App Send Status Over CAN
This is not my image. I found this here at eSk8 but this is how I built my 10s3p.
