@willpark16 has informed me that he has got photos now. Go ahead
I did this for a 10s 3p when Iām home Iāll show the more completed ine
Iām still interested in how individual cells are replaceable.
Thatās the second design this is the original Iām not at home rn so I only posted the photos I had on my phone
Lets seeā¦ 20 characters
Whereās the BMS? These are just small packs connected in seriesā¦
The pack is dissassembledā¦ also These packs have bms inside each one, one of three designs in testing
I understand this is vague rn but Im currently short a lot of cash to fund this project and the parts I do have im waiting for. I am aiming to retail some packs that are safe for travel through an airport with zero issues while also posting the designs so they are available for modification by others
Donāt market this as being air travel safe. Unless you have a Air Transport Certification, it is not worth the marketing.
If there is a BMS for each cell, what happens when the pack as a whole is shorted.
Well itās not idiot proof if thatās what you mean but i believe the bms should protect it from short circuit. Only more research and tests can give u a solid answer though
10 BMS units and each must be able to push 60ampsā¦ well that sounds expensive
Testing some bypassed bms as one solution itās really just money slowing progress
Then the bms is absolute useless against short circuit
30a is possible though, basically u sacrifice current
I donāt know what to make of this honestly.
Youāre saying each pack has a BMS, but theyāre all connected in series. And the BMS i bypassed? If so, then it shouldnāt balance the cells because you seem to have connected the charging leads with the discharge leads? Thatās what I assume because on the last picture it looks like each battery only has two leads.
Is the BMS variable? What happens if I want to go from 12S to 6S?
Ok, but amps(current) isnāt really something you can sacrifice very much of and still have a functional boardā¦
I didnāt say it was completed this is proof of concept for some naysayers there is much more work to be done but itās almost all on paper rn I donāt mind answering any questions though
