Wow man. How much does it weigh
Not sure exactly, could add up the components but too lazy lol will measure with luggage scale tomorrow. If I had to guess about 20lbs, motors, battery and wheels being the heaviest components
Got new beefy edge guard on it
http://amzn.to/2kust1mLooks amazing. Do you think you would have been able to fit a longer battery on there? Do you think the deck flex would have been an issue with the enclosure covering too much of the bottom?
It could deff fit a longer enclosure, just the only options I had are 13" and 23, 23 would be too long,18-19 could fit. The deck does not flex, at all
Do you think 23 would have fit if the motors faced backwards? I noticed that Jinra made a hi5ber board with a 26 in wheelbase that had a pretty long battery enclosure.
He actually had the 23, yes outward it would deff work and I would go with his deck if using that 23. The issue on the zenith more than the space is the taper at the center of the deck, the enclosure would overhang like 3-4"
Outward facing motors make things easier to fit overall but preclude any possibility of stealth, or standing your board up unless on pnuematic lol
Just gave it a once over with a ruler, could do 20" enclosure with tucked motors, with shortish mount Also keep in mind I’m keeping my vescs external, it’s only the battery in the enclosure
25R being upgraded to 30Q
https://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/original/3X/5/1/51329b85c8ee11a41d63c7bdfbcaeeb356e17caf.jpeg https://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/original/3X/3/9/398991914d8ecf77b76c9c8fe43f46814888bda1.jpeg
After months of searching…I found it Grip padding
https://loadedboards.com/poron-pushin-cushion https://loadedboards.com/media/catalog/product/s/l/slide_2-poron_pushin_cushion_1.jpg
I’ve been eyeing that stuff for a little while now. Let me.know if you try it out…I’ve almost pulled the trigger on it a time or two.
I’m deff ordering just trying to find a deal right now
Let us know how it performs. Might just get it if there is Black Friday deals (or cyber Monday)
Lol well I won’t get it that fast I think, unless the deals run long, muirskate stocks this and has discount code…haven’t checked if it applies yet https://www.muirskate.com/longboard/products/72692/loaded-poron-pushin-cushion
The reason I’ve been searching for it is because my E-Go2 deck came with padded grip tape and I loved it and have been missing it since getting a new deck
Yeah I have landyacthz foam grip but it’s almost to soft to be effective. This loaded stuff looks good, but really expensive. Feel like it’s not going to be on sale
@scepterr Here’s a cheaper way to go…It’s a little on the shorter side, but there’s enough in one sheet for roughly 3 decks or easily used for other stuff like beefing up protection gear or even putting some in your shoes for even more dampening. Stuff absorbs 90% of impact energy at high strain rates. 3mm@ $65.25 24x36" 2mm@ $40.35 24x36"
What a beauty!
107mm ftw
Question… where did you get that display screen for the volt capacity meter… the one you have below… only goes to 30V right? At least that is what I saw on Amazon after looking at 100’s of them. I saw other that go higher but they are larger cutout region.
Lol you are very correct that’s why it magically transformed into a different one in the following pics… They’re fine up to 8s btw, they go to 33.9
“Loaded takes no responsibility for injuries, death by guillotine, defamation, or any other negative consequences that may be incurred from the use of this product.”
Finally got the torqueboards 218 truck riding smooth, geez all the rubber bits on it are garbage. Swapping bushings and pivot cup with stock caliber made 25-30 ridable. Swapped baseplate too. But that of course was not enough, so now Bones 96A cone road side, Nipples 96A board side and RipTide 96A cup, 30-35mph smooth and straight
Winter Zenith @psychotiller SixShooters on rear dual 6374 190kv 15/60 Will get Carvon v4xl added to front next month
