Yeah I have landyacthz foam grip but it’s almost to soft to be effective. This loaded stuff looks good, but really expensive. Feel like it’s not going to be on sale
@scepterr Here’s a cheaper way to go…It’s a little on the shorter side, but there’s enough in one sheet for roughly 3 decks or easily used for other stuff like beefing up protection gear or even putting some in your shoes for even more dampening. Stuff absorbs 90% of impact energy at high strain rates. 3mm@ $65.25 24x36" 2mm@ $40.35 24x36"
What a beauty!
107mm ftw
Question… where did you get that display screen for the volt capacity meter… the one you have below… only goes to 30V right? At least that is what I saw on Amazon after looking at 100’s of them. I saw other that go higher but they are larger cutout region.
Lol you are very correct that’s why it magically transformed into a different one in the following pics… They’re fine up to 8s btw, they go to 33.9
“Loaded takes no responsibility for injuries, death by guillotine, defamation, or any other negative consequences that may be incurred from the use of this product.”
Finally got the torqueboards 218 truck riding smooth, geez all the rubber bits on it are garbage. Swapping bushings and pivot cup with stock caliber made 25-30 ridable. Swapped baseplate too. But that of course was not enough, so now Bones 96A cone road side, Nipples 96A board side and RipTide 96A cup, 30-35mph smooth and straight
Winter Zenith @psychotiller SixShooters on rear dual 6374 190kv 15/60 Will get Carvon v4xl added to front next month
OMG that looks sooooo nice. CF with sixshooter =
Lol I wish the v4 xl where cheaper😢 But then again it’s kinda worth it
you sir, make skatan proud.
if only there was some red…
There is no red without black.
Lol just noticed that was you greco new logo😂
went through the whole thread no link the front and back bumbers to stop the board getting marked
nice one scep thanks will that fir my board dju think 9 ply maple
WARNING: THIS WILL NOT FIT NORMAL WOODEN DECKS!
you need more like 1/2"
yeap. mine is 9 ply maple as well
mine 8 ply
it wont fit.
