I’ve severely modified my, what was originally a YeePlay M1.
What’s new:
Custom 10s4p Samsung 30q flat flexible battery
Koston drop-down downhill deck
Custom ABS enclosure
Abec 11 107mm wheels
Meepo (new) remote
Orangutan nipples (purple)
What’s original:
Trucks
Hub motors
ESC
I decided I’d try and fit 107mm thane over the standard hub motors to improve the softness of the ride.
I started by using a thin bandsaw to remove the original thane from the hubs bell housing…
Using a 6?mm hole saw, I bored out two of the abec 11 107s to match the diameter of the hub motors.
After that I basically used high temperature epoxy to glue the 107s to the motors.
I’m running a set of those hubs with vescs set at 60 and they don’t get hot at all. Even in 30 degree sunshine. @darkkevind Love that idea for the thane! not sure if I could bring myself to take a hole saw to new abecs though lol I’ll use some clones but defo doing it
They get too hot to touch after a 30 mile ride… However they don’t overheat and to be honest, I don’t see how this amount more of thane will make that much difference to the temperature.
Alright probably after 30 miles they might be a bit hot lol Try as I may I can not ride 30 miles on a board, shot knees and back. Maybe on the baja when it eventually arrives.
I do shit like that all the time. Still a great idea though and I will be stealing it. I’ve already set up my drill press. Got some old 90mm cheapos to practice on first. Did they stay true balance wise?
Hey there. I just love with what you done. I actually wanted to try this but I’m too much of a klutz to achieve the level of work you done. I’m just in awe because I have a Meepo V2 board. It has 90mm wheels and I wanted to upgrade them to ABEC 11 107mm as well. Terrible roads here in NYC so the extra mm will do me a lot of justice. Besides that… meepo wheels aren’t the best.
I was wondering… would you be able to do it for me. We can negotiate a payment for your labor work. DM me if your interested ^-^
Awesome work! I want to do something similar with rubber wheels. I was wondering, did you actually end up with exactly the 67mm diameter after cutting with the hole saw? I heard that because urethane/ rubber expands in heat, it might be necessary to cut with a smaller hole saw?
