Ah you have the old vesc on FOC? Probably more so that the old vesc is shitty unreliable garbage lol. Just my opinion from seeing a few go for no reason at all within my group of friends that ride lol. @Deckoz knows what im talking about.
It’s simple if you ask yourself do you want to have a bluetooth module for readings on your phone (if you wish to monitor both esc with metr pro).
If the answer is yes go canbus. Otherwise it doesn’t matter unless you want traction control, then you still need to go canbus.
I don’t even know what +5v is lol. I’ve still got alot of reading to do.
Very mechanically inclined and I’ve worked on cars for a long time but typically 60s and 70s stuff, I’ve avoided electrical stuff like the plague.
Everything except for the fact that these are skateboards is outside of my comfort zone.
The pwm consists of 3 wires: black white and red. Ground, signal and 5v positive respectively. Two focbox equals 6 wires. Subtract one red and you’re all set
By the way, if you’re still in the market for a remote, I have the benchwheel and it’s awesome. It has two channels set up so that you can run both pwm cables for two different escs without any modifications
