ok wow I didn’t think that worked before. It works
Second question. Can this app change things that might fuck with the way the board runs? Where are all the vids about how to use this app and all it’s nooks and crannies?
To be clear, it wasn’t a criticism of the app, just a suggested feature which might improve the user experience. Some of us aren’t glued to our devices, but might like to occasionally glance over our riding stats. Things like the “lifetime” stats which are a available by clicking on the profile in the top right of the screen - it would be really cool if these were somehow automatically captured. You only need to forget to log one trip and the stats become kinda irrelevant.
Maybe try the old school method of tying a string to your finger to remind you to hit start and stop. I’m also not glued to my device, but somehow I remember to hit start and stop every time I ride. I like to call it discipline. Like always putting my keys in the same place so as to not misplace them … btw no offense, I’m just messing with you. @twan is the man and in most cases does his best to make the app as user friendly as he can. You’re idea is not a bad one. Lol just a lazy one.
Regarding motor and battery parameters? You can save different operating modes and then apply to compatible esc. However, I haven’t gotten that function to operate properly with unity yet. Really wish enertion could organize themselves enough to release iOS app sooner than later
There’s a feature that auto starts logging your trip…
Also you cannot write stats to unity because of iOS limitation with the current firmware on the built in Bluetooth
No it can’t mess up your unity since the app has safe checks before writing anything to the unity
Hey @twan,
I’m wondering If you every heard of this issue: In very rare occasions when I fully push the throttle (quickly), my Vesc seems to change to some kind of ‘beast’ mode with no speed and (presumably) no amp draw restrictions.
Then it stay’s that way until I change settings trough the app or turn the Vesc off and on (not sure about the last one). Definitely not saying that Xmatic has anything to do with it but the way I see it, it can only be the Vesc itself (Foxbox) or the app (since it only happend when the app was on, but then it only happens ever to rarely).
Just wanted to know if someone ever heard of such an issue? Specs: Vesc: Foxbox Firmware: Ackmaniac but had same issue before using Ackmaniac firmware Remote: Miniremote Phone: iPhone 6s iOS 12.2
Oh and another (very small) bug: When you set your battery max in the app lower than the actual battery level, the battery symbol on the main page shows empty. This happens when I charge the battery to 41,5V but 100% is set to 41V. Because after a few minutes it drops back to 41V.
Thanks, any help is appreciated!
Ah… awesome! So that’s what auto logging is, duh
There’s a couple of extra things in settings which are pretty cool. I have it set to get speed data from the motors and distance from gps.
Tell me, for the unity should I have double data for dual config selected?
@twan I just got my Unity updated and I get absolutely nothing from the app now… I had three other users try with their phones and nothing…
Unity doesnt work at all now
Ughs… why do you guys update your firmware and expect the app to support it. You’ll have to wait until I update the app to support the firmware changes… or downgrade back
Just a heads up… No way I’m going to downgrade… My board is so much smoother now on acceleration… I wouldn’t change it back if you paid me to…
Had to update my unity in order to complete the set-up. It was fresh out of the box.
use this tool in the meantime. itll be a while before i update the app. it has the supported firmware
I still use the old version you just linked. The app seems to just drop out. Restarting the app I can keep watching my MAH usage.
@twan I installed the latest Xmatic update with the Unity fix. Was that supposed to address what I described here? There seems to be some improvement. The app keeps the connection to the Unity longer but it still freezes after a minute or two.
Is there anything I can do to help you debug the issue? I’m a software engineer and I have experience with communicating to VESC from my DAVEga project. I have successfully implemented Unity support there.
Could the problem be that you poll the VESC too frequently? From my experience, if you don’t allow enough delay between requests, the VESC starts sending invalid messages as a response. Or maybe you accidentally do CAN FWD requests, which you shouldn’t do on the Unity?
hey does the app have like a battery cycle counter? or is it possible to make one?
Hey guys! Noticed tht the voltage battery indicator is preconfigured for 30qs as im using lgh2 i want to ask if anyone has maintained the custom voltage curve for a 10s4p setup with these cells? Kr
@janpom it’s more of a Bluetooth issue. If it’s on the hm10 it’ll be fine and won’t DC but for the on board module It’ll DC after a bit. If it’s faster poll it DC’s faster and the slower the polling the longer it stays connected.
@Ruubie200 no it does not. No such function on the vesc. It would have to be built into the BMS.
I think @Ruubie200 means a page in the app where you can check a button when you have plugged your board in the charger. A little counter
