I see only this with the unity
Please email me the log in the settings menu.
Will i be able to use a nrf 24l01+ module i have an iphone
No the app does not support that module. Please get an hm10 module (you can buy from me has wires and everything) or nrf51 module.
The issue for me (I may just be doing it wrong) is I have two HM-10 modules in different boards. What is the easiest way to switch between the two boards (I assume picking the right module under BT settings)? Also, it appears to wipe out all user set preferences (as well as ride history) every time I am switching between boards. Is there a better way? Or am I just doing it wrong?
Ah! Good question, I am currently adding a feature to store multiple boards so the settings will be saved for each board. It will be out very soon! Hang tight, looks pretty too . Here’s a sneak preview.
As for switching between board you would just have to change which BT module in the settings. It shouldn’t be wiping out ride history if you change bt in settings
Hyped… It is looking good
Think I might get on this and make a Jet Spud outline ,
What line thickness are you guys using ?
Bro! This made my day right here. Looking forward to it!
You can just draw a breif outline. I can trace it out with my specs .
is Xmatic your app?
yes. it is. just type vesc in app store or xmatic
already bought it but it didnt work with iphone 7
Please give more specific details? What does not work? What ESC are you using? Firmware? Please read FAQ in settings for questions and instructions.
Hey man
Any chance you can tell us how the battery voltage corresponds to battery percentage left in the app? What do you use as 0%, 10% …100%
thanks
I have also a iphone 7 and it works good
Trying to get connect this to Metr Pro but it seems to fail. Metr app works fine.
Any tips?
[04:00:27] [USER] ~~~~~ SETTINGS ~~~~~ [04:00:27] [USER] Default BLE Device: Metr Pro [04:00:27] [USER] Motor Poles: 14 [04:00:27] [USER] Wheel Pulley: 40 [04:00:27] [USER] Motor Pulley: 10 [04:00:27] [USER] Wheel Size: 180 [04:00:27] [USER] Battery Type: LION [04:00:27] [USER] Cell Series: 12 [04:00:27] [USER] Cell Capactiy: 3000 [04:00:27] [USER] Cell Parallel: 4 [04:00:27] [USER] Charge Alert: true [04:00:27] [USER] Alert Voltage: 3.6 [04:00:27] [USER] Speed Source: 0 [04:00:27] [USER] Distance Source: 0 [04:00:27] [USER] Auto Logging: true [04:00:27] [USER] Apple Watch: true [04:00:27] [USER] Double Data: true [04:00:27] [USER] Can Fwd: false [04:00:27] [USER] ~~~~~ SETTINGS ~~~~~ [04:00:27] [BLE] Is On [04:00:27] [BLE] Scanning… [04:00:27] [BLE] Connecting to Default Device [04:00:31] [SYSTEM] Connecting to VESC… [04:00:31] [SYSTEM] Connecting to VESC… [04:00:31] [SYSTEM] Connecting to VESC… [04:00:38] [SYSTEM] Failed to Connect, Retrying… [04:00:48] [SYSTEM] Failed to Connect, Retrying… [04:00:56] [BLE] Connecting to Default Device [04:00:56] [BLE] Scanning… [04:00:58] [SYSTEM] Failed to Connect, Retrying… [04:00:59] [SYSTEM] Connecting to VESC… [04:00:59] [SYSTEM] Connecting to VESC… [04:00:59] [SYSTEM] Connecting to VESC… [04:01:08] [SYSTEM] Failed to Connect, Retrying… [04:01:18] [SYSTEM] Failed to Connect, Retrying… [04:01:28] [SYSTEM] Failed to Connect, Retrying… [04:02:33] [SYSTEM] Failed to Connect, Retrying…
I just use a 30q voltage curve. I’ll add a custom curve in the next update so you can use your own levels.
@Nubasaurus im not sure. Might be metr pro firmware issue since I didn’t develop that I cannot say much. You’ll have to ask them.
Make sure you force close Metr app in the background first. Only one app can be connected to the module at a time.
what bluetooth module do you use? I have HC-06 and it is not compatible with iphone 7
