Hey Twan! I have tried to connect it to the unity but to no avail… I think unity doesn’t support connections to ios. Only to android.
I don’t think so. So the app does not detect the bluetooth module?
No I can’t connect to the unity using the xmatic app…
The app does detect the Unity but I do not get any readings. I am running the most recent firmware on the Unity.
Thanks for the feedback! Would you happen to know what version that is?
FW 23.41 This is what is shows in the Unity app.
Guy your app is the shit! Keep up the good work!
Does the app connect to it and display Unity text on the status icon?
@Chupacabra thank you! Are you using unity?
Is this what you mean?
Sorry I wasn’t clear. I meant this page
Ah. On that screen it’s just blinking saying, “connecting vesc”
Ahhh! Ok, can you check your vesc settings and make sure in the app settings it’s PPM + UART.
It is set to PPM + UART. I have been using the METR app on it.
Ohhh does that mean you are using the metr pro Bluetooth module?!
I am. But I also have the stock unity Bluetooth module also. I would like to be able to use your app on it, also.
Me 2, so at this moment it don’t works?
Got it. Yeah as of right now does not seem to be working. I will look into it as I would like it to work
Thnx man! Btw, do you think it would be possible to add some profiles. I have 4 different boards, and each time I connect to a other, I must change my gearing settings
I can, that will be on my to do list , ill make it keep separate trips and lifetime status for each profile too.
