As the standard 1.5 to 2mm jst motor sensor cable extension are too short for my build I plan to order some with custom made length.
1.5mm 6pin jst zh male on one side
2mm 6pin jst ph female on the other side
Price per cable would be 1.75-2.00$ plus shipping.
I was interested if somebody else is interested in some longer adapter cables too and which length would be needed most.
200mm
300mm
600mm
0voters
For people with APS motors I could get an extra option (1.5mm female to 2mm female)
if that’s what you would need, let me know in the comments please.
EDIT: I will add some vesc CAN bus cables to the list.
Just let me know how long the wires should be.
1$ per cable and available from next week.
EDIT EDIT:
Here the actual pictures plus prices and how much left.
20cm 1.75$
20cm with sleeve 2.50$
60cm 2.00$
60cm with sleeve 3.50$
Shipping:
Up to 2 cables without sleeve can be sent as letter untracked 2.50$ but might take a while.
If you need more than two cables than I can sent them out worldwide tracked for 6.50$
Status:
20cm 45x available
60cm sold out - if there is enough interest than I can order some more.
Thx! I have all to make my own adapters if needed, but I hate crimping jst
So the question was just if there is a general interest in those adapter or not.
If no, i‘ll just make my own adapter.
To make this a bit more concrete,
I could get a 20cm and a 60cm version for 1,5-1.75$ a piece.
Price would be the same for both options.
If we get as min 20 people together, I would go for this.
Shipping excluding, but shouldn’t be that much as this wires not weight a lot
