I am in need of the following drive items adopted for mount to the MBS wheels. It can be either belt or chain drive components. I aiming doing dual drive so they have to be identical. Looking for both motor gear or sprocket, wheel drive gear or sprocket, chain or belt.
Please let me know if you have something or can direct me prefer US source first however if unavailable I have found in Europe.
Guys for a belt dual drive system what gearing ratio makes senses? I will be driving with 6374 190kv motors. I am about 200lbs and want a system with torque and 25mph.
I would start with Battery Min at -20 and then move up or down from there, just experiment.
I find it’s easiest to leave the USB cables attached, hanging out of the enclosure. Just leave the lid loose on the side where they exit so you can pull them out and then push them back in when you are testing. Then when you are happy remove them all together.
There’s always the option of panel mounting USB connectors so you always have config access. This one I designed to be 3d printed. Let me know if you want it and ill send you the STL.
I think there is a place in France that does the full dive in chain and sporket I had a link before I’ll look for it
It’s on my old laptop I’ll dig it out later
