I want to purchase a 2 pack of 10s3p / 10s2p Samsung 30q / 25r, depending on what you guys have available.
I need 2 of the same battery packs, when I use them on my skateboard, I will hook them up using a parallel XT-60 to get a 10s6p, and I will use a series XT-60 to get 20s3p / 72v configuration when I use it with my e-bike.
Requirements:
- separate charge/discharge port.
- BMS for charge and discharge
- size needs to preferably be around the size of a Ownboard/WowGo battery pack, I know a 10s3p will be larger, but similar dimensions are preferred (i.e. I don’t want something crazy long).
- Ready to use would be great, with a incl charge port, voltage / percentage indicator.
- I don’t know if this is possible but it would be great if the battery could fit in a WowGo battery case that would be great!
If you’re a builder quote me, thanks
