I was thinking of buying one of these 2 boards (I will probably go for the WowGo 2) but my biggest fear is getting the backwheels worn since those are hub motors wheels and I dont know if there are replacement rubber tire available or even if they are possible to be replaced.
I’m not gonna carve with it so maybe its a stupid fear since it will take a long time before those wheels become useless.
I will keep you updated regarding the shipping in case someone is interested in buying the same board. For record, I live in Barcelona, so usually the shipping is faster than any other city in Spain appart from Madrid
Hey @vishal_tejwani that happened to mine too, in the first 2 days after receiving the board! Turns out it’s an easy $5 fix, I used JBWeld from my local independent hardware store to permanently fuse the hubcap threads into the hub motor enclosure. I now have over 400 miles on the board, and still going strong. And I think I can still take apart the motor from the other side where the screws are, if I ever need to do further maintenance.
I love it! Because the controller has 3 modes (low, medium and high) I think its quite suitable for a beginner. The only think which you have to get used to is the brake which is quite hard and you will probably fly off the board once or twice before you get to “control” it, after 2 days of riding the board I already got used to it, its just a matter of changing the weight distribution which you will do instinctively once you get used to.
The only problem I “suffered” is that one day I was riding the board as usual and I noticed that it had less torque and less brake strengh. I lifted the board and one of the motors was not spinning, I turned off the board, turned it on again, and the problem disapeared and never happened again.
Oh, and it came with two controllers but I wasn’t able to pair one of them, but its fine as long as the other one works ahahha.
I use it almost everyday since I use to go to university and come back home (arround 10km). I bought the version with the 20-22km and I would say the range is more like 16km cause after that the board looses torque and speed and the ride is quite less enjoyable. Of course you can still ride it (its still quite fast) but you will notice the diference in terms of power in that last 25% of the range.
Regarding disconnection problems, which was a major concern for me since it was using a remote similar to the mini “winnin” remote, I haven’t sufferend any disconection and the board behaved perfetly.
The only electric boards I’ve tried are this one and the one I built myself (so I have no other reference) but if you have the money and you enjoy going fast and avoiding public transport, I would say go for it. Plus the wheels are quite big so its quite confortable to ride in most surfaces
