What with all the various ways you have to burn out a vesc via overcharge, I thought I’d try to eliminate one by adding a fuse to my wiring. Can someone please check me on this: The xt60 plug in the top of the picture comes from the battery, down through the loop-key, and on to the vescs. Is where I’ve placed the fusebox correct? Also, my battery is a 10s5p (12ah) so I got a 15 amp fuse. Is that right or should I have gotten one with a lower rating?
I think those car fuses are rated for up to 24V. I’m not sure it’s good idea to feed it 42v. And 15Ah is VERY low. You have to go higher than your max Battery amps
Forgot to add- my battery is 36 volts, is that okay or still too high? How do I calculate max. battery amps? Is that where the C rating comes in? As in : amps x C = max. battery amps? If not, what fuse should I get?
You said your battery is 10S. that means it’s nominal is 36v but the maximum voltage at full charge (4.2v per cell) is 42v. And the max is what you have to look for. A 24v fuse could work but when it blows it might not blow properly enough and not protect your electronics. There are some specialised fuses rated for 58v in mouser for example.
The amps have to be rated for the maximum current you might have or want. The maximum current a battery can give is its amps capacity multiplied by its c rating. If you are ussing a vesc you can limit this value to something lower (max battery amps)thus this would be your Max amps
Search and read
The cells in my battery pack are Samsung 25r’s. Their 3.7 volts each so shouldn’t it be 37 volts instead of 42? Based on a quick read through the above links, most folks seem to be going for a 58v fuse, like you said. I was hoping to find one that would fit in the housing in the pic I posted.
Nope! they charge to 4.2v per cell.
I have never found a fuse so small it could take 58v sorry. As I said your cells are 3.7v nominal. That means they are around 3.7v at medium charge (for simplification. Read on nominal voltages if you need something more precise) so let’s say at around 50% charge they have 3.7v. When they are completely depleted 0% charge they should be around 2.8-3v depending on the life you want to give them. And when they are fully charged they are at 4.2v. You could go higher but that would damage your cells. So on a fully charged 10s pack you have 42v.
Your cells have a maximum of 20A discharge. With 5 in parallel you can expect 100A maximum discharge from your pack. If you want to be able to get all that juice out you need a 120-150 fuse. Or lower if you set limitsl
Woah, okay thanks, that clears up a few things. I hadn’t considered the max. discharge properly. So let’s say I want my board to be able to climb hills decently but nothing too steep, and odds are I won’t be going full speed very often- what would a good setting be? I see lots of people seem to set it at 60 amps. For that matter just how helpful is the fuse? Since I have FOCboxes I assume that their heat-sinks would help somewhat prevent these problems, but how much?
Once you find the right fuse, it gets wired in just like another loop key.
That’s exactly the plan, put it in-line right after the key. I’m just trying to figure out what fuse to put in there, if there’s even one that’ll fit it. Someone told me that because these are automotive fuses they tend to take a bit longer to burn out if they’re put over their rated current, which might be a problem for the electronics. Anyone know about this?
I’d put it inline right before (closer to battery) the key
There aren’t many fuses that are >45V and >100A that would physically fit in a skateboard. I did find one but the selection is very small.
edit: none of those are in-stock, either…
What’s the difference? Thanks for trying to find one anyway. I’ll look around and see what there is. I’m really curious to know whether my focbox heat-sinks will be enough on their own, that way I could save myself some hassle.
The fuse is not there to limit the amps to the vesc and protect it from overt heating. That’s what the amps and temp limit are for. I think the focbox is rated for 60A but not sure. Fuses are there to prevent shorts from damaging your vesc and batteries. A fuse “should” never blow under normal conditions while amp limits should quick in when you get near your limits like prolonged hill climbing. If you are only using a single focbox limited to 60A you could do with a 80-100 Fuse as in normal conditions you would never get near that range meaning if it blows there was a short. Or If you are ever planning on going dual you could use a 120A fuse limiting both vesc to 50A or a 150A fuse going dual 60A (these would be me)
This is perfect, thanks! I can only get 100 amp ones at the moment, and I have dual FOCboxes. If I set them to 50A will that be okay? Bty, the size difference between a 100 and a 150 fuse is MASSIVE!
The Thing is. When you’re fuse is so near to your maximum values thru could blow off when driving to your maximum. 100A is a beast of power. But limits could be slightly overpasses while the vesc adjusts itself and fuses have tolerances. Ie it really is 100A ± a small percentage. And you really don’t want your fuse yo blow if nor 100%needed. I would really leave a margin between your limited maximum and your fuse value of around 20% but that’s up to you.
From Mouser Spain I can get these in 100 125 and 150A http://www.mouser.es/Search/m_ProductDetail.aspx?Littelfuse%2F14256316122%2F&qs=sGAEpiMZZMsh2y49K8ANrTdpOrToc%2bEOWEps5yIgKK0%3D
Thanks for the advice. I just ordered a set of four 150amp ones on ebay. As you say, better to have a safety margin. http://www.ebay.com/itm/4-Pack-150-Amp-Mini-ANL-Fuse-Fuses-Gold-Plated-Inline-Quality-150A-/192124248960?hash=item2cbb7f6380:g:VHQAAOSwcj5ZVEAH
Hi, how have your fuses been working so far?
Aren’t the fuse amp ratings also related to volts of the application, so that a 150A car fuse will blow at around 150 A when voltage is around 12v. Using the same fuse with higher volts will cause fuse to blow at lower amps, no?
I’d guess this would be related to max watts of the application, so that a fuse that blows at 80 A with a 10s system would actually equal a 280 A rated car fuse (12v). I might be totally off, but maybe someone with more knowledge could correct me?
