As the title states I would like to have someone check to see if my wiring is correct. Question 1: Is the loop key in the right place? Question 2: Where does the voltage meter go? Question 3: Will this bypass the BMS for discharge?
Here is the BMS
Here is the BMS
No; you want the loop key on the negative line, between battery negative and ESC negative. Also it helps to make thick lines 10AWG and thin lines 22AWG
Yes, this is in “bypass” configuration. The voltmeter goes in parallel to the ESCs, just like if you had a third ESC, but it can use 22 - 26 AWG wire
Thanks, I’ll redraw it real quick.
Yes; except the wire from the battery to the BMS “B-” doesn’t have to be 10AWG because P- is not connected. 22AWG is okay
Alright, thanks for the help.
Pay attention to the BMS if it starts “B0, B1, B2” or “B1, B2, B3”
Some need the B- to be the same as B0 and some start with the next cell for B1
I think it doesn’t matter the side of the Antispark loop, plus I would rather leave my electronics grounded with the positive disconnected. Just my 2¢
The schematic looks good, but for future reference when drawing crossing wires, to designate they aren’t connected, draw the wire like the Omega symbol as if the wire is “going over”
Is there any way to tell which one it starts with or is it just trial and error?
Do you know which BMS it is or have a photo or both?
I haven’t bought it yet I was thinking about using this one.
Yeah that one has 11 connections instead of 10, so B0 through B10 or 0V through 42V, as opposed to 4.2V through 42V
Your diagram only has ten balance wires and not eleven
I’ll draw it again, brb.
Also the series connections between the batteries need to be large wire
So, when I was sketching I couldn’t figure out which ground wire I needed to connect to B0. Could I get some help? 1 is for the main wire and 2 is the smaller one in the middle
Hi, can anyone just take a quick look at this whirring and tell me if it is right(I will bypass the BMS). Do I nead the black whier form battery 2 to B- on the BMS? this is the BMS i use. https://www.ebay.com/itm/10S-36V-Lipo-Li-Ion-Batterie-Charger-Ladegerät-Schutz-BMS-PCB-Board-mit-Balance/263914313397?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Thanks
