I just finished building a mountain board (10" pneumatic knobby tires) with this electronic setup. It works great, but it starts terrible. The motors just chatter like crazy on startup. But once I get it going it runs great.
I’m thinking I need to swap out the Jeti Spin Pro ESC’s for ESC’s that are designed for electric skateboards. I like the VESC in theory, but I’ve heard a lot of folks are smoking them. Will this config work with the VESC? Any tips to avoid smoking them?
Those are $500 ESC! Crazy. Yeah you really need to run those batteries in series not parallel. Also of you’re running a uncensored setup the motors will jitter if you start from a standstill. What’s your current gearing for motor and wheels?
I don’t know if those ESCs will have regenerative brakes, or brakes at all, and if they do, if they will be smooth enough to not toss you off the board.
Right now you’re kind-of limited to FOCBOX or ESCape, and FOCBOX aren’t available at the moment. The ESC market is in a transition at this point in time.
