Yes that’s one of the ideas behind the mount solution. Same hole pattern for all plates and trucks
So the motor plates needs to have a center to center distance of 80mm instead of 72mm to fit on the Surfrodz as well as Calibers. This is how it will look except with 12mm motor pulleys:
Looks great. Are they mounted on a E-caliber truck in the pictures above?
no, those are surf rodz tkp trucks.
@Indiangummy is right. You could use them on E-calibers also with the caliber clamp if you like. I will split it up into different configs on the website when they are ready.
I have the longer motorplates for rearward mounting in the works now, any feedback is appreciated.
C-C distance = 95mm ± 4mm
Black AL7075 6.9mm thick, 5.9 at motor.
Fits clamps for SR TKP, TB218, Caliber
Bonus: Possible to run 50x motors as well with adjustable idlers.
beauties!
oops. forgot this: 10 chars
Nice job!!
Thanks! I will produce these, the 80mm motorplates, tkp clamps, 16T motor pulleys and maybe some modular Kegel pulleys 36t, for 12mm belts.
Also there’s 20%off on the fixed mounts on the webshop from now until next week!
I just bought the " Dual mount complete – with idlers and crossbars" from the website! Your mount design is the only one that ticks all the boxes for what I was looking in a mount (reliability).
It looks very well studied and well thought out! I like all the possibilities without compromise.
And those … hooooooo I want to ride your board man !! Is it going to be your own esk8 ?
I have spent way to much time designing these mounts
Yes, it will be my own esk8, you can have a go if you visit Tromsø some day
I posted my first impressions of the dual mount kit (without taking it to the road yet) in another thread:
Thanks. It’s 90mm
@gmurad Here you have it for 90mm wheels without idlers: https://www.thingiverse.com/thing:3469290
Will make some different versions and put on the website later.
Thanks! I will print these and try. Will report back with a picture
