What type of (spray) paint would work on a blank deck? Any recommendations?
I’ve heard automotive paint looks the best but I imagine any 'ol paint/primer/clear coat will be fine as long as you put good work into it.
Thanks for the advice, I’ll give automotive paint a try.
Hey!
Don’t know enough about paint to give any suggestions but here is what I did.
First I sanded my deck.
Applied 3 layers of primer
Applied 3 layers of black paint
Applied 3 layers of clear coat
2 layers could probably had done it, but…
Thanks for the detailed reply. I’ll give your method a try, see what works best. Cheers!
Use urethane based car paint and primer. Anything spray paint will run, will fail to adhere
