FOCBOX UNITY $299 | R-SPEC DRIVE KIT $588
Which esc would be a better option
#1
i dont know which to esc to pick between.
Link #1
http://www.hobbyking.com/hobbyking/store/_28377__Hobbyking_174_X_Car_120A_Brushless_Car_ESC_sensored_sensorless.html
link#2
http://www.rcjuice.com/fvt-120a-brushless-sensored-sensorless-car-esc-2-6s.html
my motor
http://www.ebay.com/itm/5065-50-65-270KV-Heavy-duty-brushless-Sensored-motor-2-6KG-3-8S-for-Skateboard-/181913685694
#2
Do you mean esc?
#3
yes… mistake
#4
Can’t use the first one…is only good up to 3s
#5
I’m using the same motor
#6
Go with the FVT 120a from rcjuice I have great experience with them and have not had any problems with the same esc
You could also check out this thread
#7
alright thanks
#8
how good is the motor
#9
We shall see seems fine…only time will tell…I’m using the motor of a light build in a Sensored configuration
#10
It’s tough to find a motor in the price range
#11
To be honest I’d recommend that you move up a motor size to 63mm motor for your first build …
I know how the board I’m making will be used…no hills …on flat ground…and it won’t be pushed to high speed …so I know The 50mm will be fine
#12
well thats what i will use it for. only flats
#13
Then should be fine…
It’s a sensored motor so I figured I’d just use a sensored esc
