Just bought 2 vescs from enertion, not the new one, and am planning on connecting them via can bus connector. Where do I connect the receiver for controller?
This may not help with dual vesc ( I only have experience with 1) but your receiver connects to the 3 pin plug on your vesc capacitor side. You may have pins or you may just have solder pads. It depends on who you bought it from.
do a search using “CAN bus VESC” you should find clear instructions
unclear instructions: one vesc is your master, he will have the ID 0 and you will connect the servo wires to this one. He will be driving the show. the other vesc is your slace, he will have the ID 1, he listens to the master and takes commands or he will be punished.
