2.5mm charger will be hard to find.
Just get the 2.1mm. I use this exact one at 3.5a charging with no problems. Not sure about 6a but I suspect should be ok.
Thanks for the answer. I didn’t know 5.5mm x 2.1mm was standard.
Unfortunately I bought 5.5mm x 2.5mm connectors and chargers. I’m assuming it’s safe to use 5.5mm x 2.5mm as long as the charging port and charging connector are matching specs?
Yep, just don’t trade parts or try to use any commerical board chargers or anything except use those 2 you have together, and cut the connector off if you sell it
