hi,
i use this battery capacity indicator
http://www.ebay.es/itm/2016-Battery-Capacity-Tester-Indicator-for-12V-24v-36v-48v-CAR-Lead-acid-lithium-/172143986261?hash=item281494c655&_uhb=1
i’ve a 12s setup 44.44v (2 batteries 6s 8000mah 35c 22.22v each one), they are almost full 99%
battery 1 - 4.19, 4.20, 4.20, 4.19, 4.20, 4.19
battery 2 - 4.19, 4.19, 4.19, 4.20, 4.20, 4.20
i use this power switch
this is a picture of my build, i only want to show the capacity indicator when i turn on the switch
but the battery capacity indicator only indicates 84%, why? any idea?
thank you
lox897
October 7, 2016, 9:10pm
2
It might be on the wrong mode. There is a button on the back. Hold this down as you power the board on and you should be able to change the mode.
Jinra
October 7, 2016, 9:22pm
3
Also, your power switch might melt given it handles such low current.
rpn314
4
Yeah, wiring looks great. Definitely some configuration issues
thank you for all your responses!
@lox897 yesss!!! it works! when i turn on with the button indicator pressed i can choose an option from 0c to 15c, then to save the setting turn off and turn on again.
lox897
October 7, 2016, 10:33pm
6
Awesome. Set it according to what 12s is.
Personally, I think it’s better to monitor voltage.
It doesn’t seem like percentage meters are accurate enough.
Also, you need a high voltage anti spark switch.
The switch you have won’t hold up.
Any recommendation of volt meter?
I think the meter you have can switch to volts.
