I’m new to understanding this, so I plan on getting a motor with 230KV from the torgue diyelectricskateboard guy and running a 7s6p battery through it.
To help me understand for dummies, is there significant downside to not reaching the 7000-8000rpm people recommend? So far according to the math sheet, my RPM will hit 5796 (after all calculations)
everyone says 10s is the best of both worlds, but I find 12s works even better, especially with hummies hubs. And no issues on stability with the vesc for me…
for sure! If you keep the kV low enough you shouldn’t have many problems. The main issue lies in voltage spikes during braking that can cause errors/damage in the VESC on larger motors. I’m betting, with the VESC 6.0, these will be non-issues.
Thanks for the great insight! I’m really happy I get to learn allot
What do you mean by voltage spikes? Also asking from experience, do you believe running a 7s or 8s setup would cause a significant enough of a heatup for me to be concerned?
I intend to be driving at most, 20-30km/h and setting up my VESC with a remote capable of throttle control (probably wiiciever and nyko wiimote) for steady progressive breaking
I also intend to encase my battery and vesc in a carbon fibre casing
Voltage can spike during braking to unsafe levels (for the VESC), though I’m unsure as to what causes larger spikes. Given the naturally higher voltage of 12s, it’s more prone to this than 10s.
People run with 6s setups all the time, I don’t think you’ll run into issues unless you’re working the motor really hard. I hear the wiiceiver is pretty unreliable, but haven’t used it myself. Try not to make your entire enclosure in Carbon fiber as encasing all the electronics in that will cause you to have poor signal.
Ah alright I see now, I guess i’ll have to do more research on what controller I can get that is both compact and has good throttle control.
Based on my experience reading the forums, the wiiciever seems to only have reliability issues when it isn’t soldered to the contact (however I may be wrong, there arent really any live cases or video’s I can find of someone riding and using a wiiciever however I have found people on the forum who love it and have 4 of them.
In terms of the Carbon Fiber thing, I think it should be fine for me, the carbon fiber enclosure will only cover the bottom portion and it seems like boards such as the raptor or this guys https://endless-sphere.com/forums/viewtopic.php?f=35&t=75291 dont seem to have any issues. Based on my basic understanding of signal interference, wouldn’t the carbon fiber only have an effect if it was in-between the electronics and me?
Yep you’ll be fine as long as it’s not completely encased in CF. The raptor is fine because the lid is made of glass fiber instead of CF. The original Raptor had a CF lid which blocked signal and caused cutouts.
