Looking to create a dual drive 12s setup (2 6s 5000mah 25c) but am finding it hard to pick a pair of ESC. Some sources say that the VESC cannot handle 12s lipos. Is this true? What other options do I have then. And when it comes to dual escs has anyone tried this one: https://flipsky.net/collections/electronic-products/products/dual-fsesc4-12-100a
When it says ‘100A dual’ does that mean each ESC can pull 100A or each can only puppy 50?
Thanks so much in advance
(PS if any one of you know builds with a similar power pack please link them here. I’d like to know what housing options they’ve used, BMS and range they got on their boards)
Your questions answered by reading the specs you added to your post.
All vesc Derivats work with 12s.
Some more reliable, some less.
If the producer recommends a 10s use, than there is a reason for it
If you want to see builds with similar battery than you plan to use than just use the search function.
You definitely not the only one in here with a 12s 5Ah lipo battery.
Man I can’t think of a worse vesc than the one you linked for your use case.
For me at 12s It’s either Ollen-vescs or Enetrion vesc-x’s (which you can’t buy directly from Enertion anymore)
Now I’m not recommending anyone go the 12s route but If i would I’d only use those esc’s at this time.
If you wanna be a bit more safe then you could maybe go for a dual receiver setup
(that way if 1 esc fails your remote will still have control and handle the other.)
