Thank you Chris
That was a fun little design project!
Bruh, u need 2 start cutting for EU peeps!
That is tight as hell, good job.
Thank you, that means a lot! Never used a cnc before so it taught me a ton.
Got mine! Thank you very much!
I saw the instagrams pic.
I woke up in the middle of the night and ordered a set while being half asleep. I don’t have any regrets.
I’d like a set.
Signed form.
Any chance to work on the nut holders?
U guys are funny. Imma do my best to get them our asap. Im on vaca. cruising in charleston, sc.
Damn. @Colson003. Imma give it a go. Is a pita cause small endmill, but i need to make some to see how it do. Ill make u a set.
Hell yeah! if you could make two full sets for me that’d be even better, I’m working on two boards right now. I’m using imperial hardware atm
You talking about something like this? (I know posted earlier) I really want something like the X things with the bolts built in so you only need one tool when working on the trucks and so you don’t see Hardware from the top side of the deck
No, there’s a drawing up there somewhere. They do what the name implies, they have grooves that hold the nuts in place so you only need a screwdriver.
Ideally I’d be able to cut a recess into the board so I could grip directly over the x thing and see nothing
Huh. Thats an idea, but would need setups for each board. No impossible tho.
I probably just do a rectangle the size of a caliber truck base plate to make it easy.
Just filled your form in
