Nah, dey a diffn’t ting.
Not yet @Colson003. I need to figure out how to squeeze out a few more hours a day.
That sound like an argument you here in the gym about cups
Yea id like normal set
someone earlier spray painted it successfully but you probably need to really sand the surface and use a proper metal primer and lay on several coats
I’ll design and 3D print one to get the exact dimensions. Presume you could then take my model to get the same gcode for cutting?
yep. just need the .stp
I just put my first set of washers in a vibration tumbler overnight in walnut media. It was all my buddy had because he normally uses it for polishing brass for reloading ammunition.
That media/substrate had literally 0 effect kver 12 hours, lol. I figured it wouldn’t, the walnut seems way too “soft” or “fine.” I figured might as well see.
What do you think would be best to tumble them in @akhlut?
Yep. Walnut will do nothing. I think it needs a ceramic media to remove tooling marks, scratches, etc. I need to pick my buddies brain to get the right stuff.
Keep me posted, I am going to do some research as well and will grab something or other…I will LYK how it goes
Could you use blast medium…you can get various including walnut but glass maybe good?
I was thinking about glass as well
Soooo…
Apparently walnut treated with a polishing compound is the bees knees:
http://www.gravescompany.com/Grit-and-Media.html
And then there is this:
This is a total rabbit hole.
Personally I love the rough machined finish, it screams bespoke which it is
I guess the wrong polish was in here, because mine did absolutely notheing over 12 or more hours. Strange
Sorry to be impatient but when can we expect a new batch to be produced?
same question from me
Work and fam are trying to kill me. I just got 60 lbs of aluminum in too. I have a shitton of stuff to finish today, but I’m hoping to get started this afternoon.
Sorry for the delay fellas. I’m on it.
excellent just to check I’m on your list right?
checking it twice…
