Ok cool any idea what they’re called
X-bolt is what Chris Chaput (Abec11) called them. Good luck finding them. I swear they’ve been out of stock for a decade
Might have better luck finding a “U-bolt”
Lol I’ll give up now then.
Hell, I can make you a set. They’ll just be raw aluminum though - I can’t anodize…yet.
hmmm what’s the point of having this “X” if the bolts are not permanently attached to them? Not using two tools to remove trucks would be awesome. just had to install the Shred Light brackets on three boards
These will allow you to torque the bolts without the heads sinking into the deck.
IMO, oversized washer. I would maybe put this on the top mounted drop through deck to cover the hole. Maybe
chris told me about those. they seem like a great idea. Not sure why they fizzled out. I’d use them.
That’s exactly what I did on my board. Top plate out of 3/16" aluminum to stiffen the drop-through and a 1/4" aluminum riser below. Resulting pocket provides a handy space for the battery meter.
https://www.muirskate.com/longboard/products/69461/rogers-bros-studded-hardware
These are basically the same thing. I use them on my board right now, they’ve lasted me over 4 years of use and make taking trucks off sooooo much easier.
i’m not so sure its an obsolete product more one that hase’nt really hit the market yet
seems to be these guys
i like the idea of putting the battery meter here
Hey there…are you still up for making these? If so, how much would you charge?
Yeah, i can get you a set. Not sure on cost. Probably cheap though, maybe $15 for a set?
Awesome! I would like 2 set (4 total), raw is fine. I like the look better than just using a washer. let me know when you finalize design and production and I’ll paypal you (shipping in CA 92618)
Ok. Will let you know. Ill probably cut them this weekend. What bolts are you using?
