I’ve seen on some boards what looks like a reinforcement X mounted on the deck side of the truck. What are these
Thank you
James
Thank you
James
Got a pic? I’m not sure what your referring to
Can’t find one for looking now, it’s basically in an X shape going to each bolt that goes through the board to the truck
It replaces the 4 bolts normally used with one piece of hardware, eliminating the need for two tools to tighten. Then you only need a wrench
Ok cool any idea what they’re called
X-bolt is what Chris Chaput (Abec11) called them. Good luck finding them. I swear they’ve been out of stock for a decade
Might have better luck finding a “U-bolt”
Lol I’ll give up now then.
Hell, I can make you a set. They’ll just be raw aluminum though - I can’t anodize…yet.
hmmm what’s the point of having this “X” if the bolts are not permanently attached to them? Not using two tools to remove trucks would be awesome. just had to install the Shred Light brackets on three boards
These will allow you to torque the bolts without the heads sinking into the deck.
IMO, oversized washer. I would maybe put this on the top mounted drop through deck to cover the hole. Maybe
chris told me about those. they seem like a great idea. Not sure why they fizzled out. I’d use them.
That’s exactly what I did on my board. Top plate out of 3/16" aluminum to stiffen the drop-through and a 1/4" aluminum riser below. Resulting pocket provides a handy space for the battery meter.
https://www.muirskate.com/longboard/products/69461/rogers-bros-studded-hardware
These are basically the same thing. I use them on my board right now, they’ve lasted me over 4 years of use and make taking trucks off sooooo much easier.
i’m not so sure its an obsolete product more one that hase’nt really hit the market yet
seems to be these guys
i like the idea of putting the battery meter here
