Uhhh it certainly will. Flat objects on warped surfaces are still flat.
…or are you a flat earther
Bro, that warped bed will bend your sheet of glass, I know it because I tried it…
If your thinner aluminum bed is bending thicker glass, Idk what to tell you. Did you use really thin glass?
I’m using 3mm with a buildtak like material on top
3mm gloss finish.
And you didn’t buy it from a meth addict?
Straight from china
I noticed how you clamp the bed affects the level which made me think my glass was slightly warped the glass was flat but changing how I clamped it fixed my issues.
I just had 4 included clips on each corner.
I had to move all my clips to just inside the levelling screws. Also try printing on the other side.
But I mean try to bend a sheet of glass it’s not exactly easy.
This is also where I have my clips. Aluminum bends more than glass does.
Has anyone here used the Up Box? I had access to an Up Plus 2 back when I first started learning to print and then the Box came out and had good reviews. Quiet, fast, lots of material options and it has a HEPA filter. Supposedly it’s a good “set it and forget it” one. Does anyone know?
Yep the print bed got warped from me spimply pulling the magnetic bed stuck with a large print. All good now using a glass bed and its printing again finally.
Got my bl touch
Ordered a rasperry pi and camera to use with octoprint and a microswiss all metal hot end and some cool filament
Do any printers come with scanners built in?
Like a 3d scanner?
yeah a 3d printer with a 3d scanner built in?
I’ve seen a few but there’s also a 3d printable rotating base that you can use your phone camera to scan. I keep wanting to try it.
Here’s the link if anybody is wondering.
I saw the davinci 3 in 1 pro has a scanner built in but I dont like the non removable metal bed
