RONIN precision axle stub https://grabcad.com/library/ronin-precision-axle-stub-1
Ronin Billet Trucks 2014 / WIP https://grabcad.com/library/ronin-billet-trucks-2014-wip-1
that would be great, are the parts (hanger, baseplate, that thing in the middle) seperate?
Hey guys, I am working on a 110mm 70a PU sleeve option for the meepo boards, primarily targeted towards the AWD GT. I could really move a lot faster if anyone has a meepo sized (90mm) hub motor sat/step/solid file, or even better a model of a 90mm pu sleeve for meepo hubs. Thanks a ton!
Team, need your help please - does anyone have an Evo model?
If Iām dreamingā¦ Evo with SR RKP and 100 mm Boas?
(this is for our eLofty/Ownboard AWDD-on-SR-RKP-project using an Evo I bought from @bigben - I would like to understand what it is I am investing into thanks friends
Hey @mishrasubhransu
Just wanted to ask if you still have these solidworks files available for the battery packs?! Can not access without requesting access.
Wanted to play with it to see how I could adapt it to my needsā¦ Thank you very much in advance.
Greetings Ron
hi @topcloud: i have evo+ sr rkp 200mm trucksā¦unfortunatelly the build still in the works. I will put Faboy core from Kugs + evolve pneumies/ gummies. Belt driven for now. Lets see how it goes. Curious to see yours runing DDās.
Maybe this will help.
Hey, I restructured a lot of the directories and purged a lot of the older files but I still have the original part(from agnius the creator of NESE) that I just added hinge to. PM me your email address and Iāll share it with you. But know that this is a older design and @agniusm has since upgraded them. You can find the files(look for google drive link) in NESE thread. Agnius was supposed to create a new thread with all the information in one place but not sure if he had the time to get to it yet.
Does anyone have a MBS Rockstar II hub modeled?
I love this thread.
Anyone have a gearbox ?
I have some Fusion 360 models of some esk8 things that others might find useful.
Is this the best place to share them?
Yeah I guess
OK so I have made these models myself with the part and a pair of calipers. They are as accurate as i can make them without original cad. If a dimension is included its probably cause i measured it, but that doesnāt mean its the same as your part and i recommend checking any important dimensions before committing to making something based on any of these models.
That said, in no particular order, here we go . . .
FOCBOX - https://a360.co/2Jdm3Bs -This model has accurate heat sync if you ever want to make your own.
FOCBOX UNITY - https://a360.co/2Ua0OTk - as accurate as i could get it inside without taking any screws out.
FOCBOX UNITY Switch - https://a360.co/2JhXcwG
LLT Power 10S-15S smart BMS with Bluetooth 20A to 30A - https://a360.co/2J0nmVj
Bestech HCX-D131 - https://a360.co/2JcJ2Nf
Trampa Street Carver Deck - https://a360.co/2SLjigP - Unfortunately no holes but it is a āsheet metalā part so it does fold flat.
Trampa 90mm STICKIES - https://a360.co/2Jg96a1 - with 9.XXmm bearings
Trampa ULTIMATE Mini Spring TRUCKS - https://a360.co/2DU2HgI - lots of rads done by eye in this one so make sure to double check things before making motor mounts based off this.
StreetWing 6374 - https://a360.co/2IZV8dd - dont think they sell this motor any more but its the same as some from other vendors so ill post it anyways.
HTD5 Pully Parametric Model - https://a360.co/2JdnHmC - got to Modify -> change parameters to alter the number of teeth and watch the magic happen.
4p 30Q with Kaly Cell Fuse PCB kit - https://a360.co/2HarzCz
Kaly Enclosure for 18650 12S-4P - https://a360.co/2VhPxFC - This one is rough as lots of dimensions are hard to get accurate measures for but I did my best.
MR60 Male - https://a360.co/2JgqqM7
MR60 Female - https://a360.co/2IZdATp
XT60 Male - https://a360.co/2J0mdx0
XT90 Male - https://a360.co/2JhjfmU
I release these models with the intention of encouraging innovation and helping others plan their builds before parts arrive. @onloop @trampa @Kaly if you would prefer these not shared then let me know and i will remove them.
BONUS: Kaly build im planning made from parts above:
Also a Modified trampa truck with built in dual gear drive that i want someone to make:
Amazing resource
Thanks for sharing. Really nice models.
Good work, really good.
Nice job on this, awesome!
Have any tips for rendering in Fusion 360? I would love to see your settings. Mine look like shit no matter what I do
