i’m currently trying to finally set up my board but so far i’n not that happy.
Compared to other build, the sound mine makes is a bit weird. Its shrill and clicky? And second the performance. On the video without me on the board is full throttle. I’m not sure if it is configured wrong or whats the deal. Any ideas?
I also wish that i could configure 2 speed modes with my nano remote or use the reverse button, Smoother acceleration etc.
I’ve uploaded 2 Video to youtube to demonstrate it. One is without and one with me on the board.
@xsynatic What are your voltage cutoff settings? What are your current settings? What are your settings in general? Post screenshots/pictures/descriptions.
Well you never do a detection with the belts on probably not causing the issue but I would redo it to so you know. Like @MysticalDork said post a screen shot of your settings. Also your belt seems super long for standard mount mount and none pneumatic wheels
Well one thing I noticed is you motor max is 85 and the TB’s max is 80 So I would change that. Reason I said your belt seemed big was because you stated it was 470mm in your OP. What type battery are you using I’m guessing 8s?
Well 190kv should be ran on a 10s battery that is the nice sweet spot for 10s it will work with 12s for a 6s battery you want something with a higher kv. How much of a charge does your battery have?
So, to clear maybe some things up. My build was inspired by Skatemetrics Patriot.
I basically use the same Motor,Battery and VESC. Only in a different configuration (Signle and street for now)
Ok so a few things they are using that are different a dual motors which and the 6.6 vesc you are using the 4.12 vesc which has a max amp of 50a there is 100a per motor so that is very different and you need to change your motor max to 50 because prolonged use will probably blow the vesc. They are also using different motors than you so it is different and you may be using the same batteries but they have 2 wired up where you have one that makes a difference in the voltage. If I did the math right your battery is capable of producing 144A so adjust your battery max.
In those pics, your battery current is set very low at 20A… I’d go with at least 40A for battery current max, probably more like 50 or 55.
190KV motors are really most suited for 10s batteries. You may want to get a pair of 5s packs, or a 4s to pair with your 6s. (Just make sure the brand, capacity, and C rating all match.)
