Hey guys, have you encountered an issue when you’re using multiple vescx(focbox)'s where the master is controlling the slave, but the master throws over current when at high rpm. AND only when traction control is enabled.
Only way to resolve it is by disabling traction control. At lower RPM it’s not too much of an issue. However once over 25k erpm, you start seeing small spikes. Eventually at even higher rpm, the master will just shutdown leaving the slave spinning.
