Has anyone tried to water proof their eboard with a product like this?
I just blew up my speed controller and BMS by getting caught in the rain. I would like to add a non-stick silicon layer around my electronic compartment and was also thinking about spray something like this nano-protect on all of my electronics.
How did water get into your board? I dont ride in the rain, and i find it quite dangerous.Also my enclosure is made out of perforated metal.So i cant really help you, the best bet is the rubber seal.
So on top of the Evolve GT carbon deck is a screwed in lid that does not have any rubber seal, so I thought I would try to find a non-stick silicon sealant so I can open and close the lid. Not sure if looking for a custom rubber gasket/tape type solution would be better…
@Rinzler I actually use something very similar around the seal of my enclosure and it works quite well! It does however add about an inch of depth to my enclosure which is already quite close to the ground so take that into consideration.
Also you could use Corrosion X or some other type of waterproofing agent though what I’ve seen work quite well is just covering your electronics in some type of silicone and spreading it over everything.
@tyhuelle just wana get yourself some weather seal comes on a roll,one side is adhesive and comes in different sizes,works really well on the enertion enclosure!
10m Assorted Profile Draught Excluder - EPDM Rubber Draught Seal and Foam for Window or Door (Profile D, Black) https://www.amazon.co.uk/dp/B00NJ0W380/ref=cm_sw_r_cp_apa_eCgPzbYWW9M1P
