Been here a while reading everyone’s stuff. I learned a lot so I have decided to makes my own build thread to help others causes this forum has a very nice community will to help others. Been working on my board for a while but I reconsidering my battery. This is the reason my board is taking me so long.
Here is my build list with almost everything I used: Five Mile Warhorse 53 http://www.ebay.com/itm/Five-Mile-Warhorse-9-75-x-38-Downhill-Freeride-Longboard-Deck-/131544919866?var=&hash=item1ea0b02f3a:m:m4z_w8upF2sBFspzPwaSElA Tacon 160 245kv Motor $63 Wheels: (Cheap with bearings) $22 http://www.ebay.com/itm/Blank-Pro-83mm-Multiple-Color-Longboard-Flywheels-ABEC-7-Bearing-Spacers-/151149290150?var=&hash=item23313322a6:m:msGM40c-xzuJTAwOVnibhoA 83mm Gears: (this ended up being around 60 or 70 buxs cause of shipping. Just buy a belt drive from enertion if you dont want to use chain drive) http://www.bbman.com/catalog/product/25B36 http://shop.sdp-si.com/catalog/product/?id=A_6C_7MHK2514 Chain: $15 http://www.ebay.com/itm/25-25-1-Roller-Chain-10Feet-with-2-Master-Links-ANSI-Standard-/321765763022 DIY’s V4 motor mount (I had to modify it though cause of the tacon 160’s protruding c clip. Will post picks later) $85 Black Caliber Trucks $50 VESC: $100 http://www.enertionboards.com/electric-skateboard-parts/vesc-motor-controller/ Remote: $25 (holy shit the remote is now 40 bux! I would recommend the nano remote from DIY instead) http://www.amazon.com/gp/product/B0047SFGDW/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687702&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0012R58LG&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1XZZZNPK7C3BFTD0CGYK Battery: $23 (i got zippy batteries but Turnigy batteries are slightly better and cost the same amount) Only using 3 of theses lipos for 9s cause I dont want to go above 60k erpm and harm my vesc. http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=8579&aff=1086883 Charger: $30 http://www.hobbyking.com/hobbyking/store/_5548__IMAX_B6_50W_5A_Charger_Discharger_1_6_Cells_GENUINE.html Power Supply: $8 http://www.amazon.com/Intocircuit-Adapter-Charger-Benq-Monitors/dp/B0023Y9EQC/ref=pd_sim_468_1?ie=UTF8&dpID=51I0Eli2jpL&dpSrc=sims&preST=AC_UL160_SR160%2C160&refRID=1QRMVP331K6FP4W3CD18 Charging board http://www.hobbyking.com/hobbyking/store/_14856__HobbyKing_Parallel_charging_Board_for_6_packs_2_6S_XT_60.html xt60 connectors x2 3 http://www.amazon.com/OOOUSE-XT60-Connector-Pairs-pairs/dp/B005FAPYXS xt90 connectors 9 http://www.hobbyking.com/hobbyking/store/_24707__Nylon_XT90_Connectors_Male_Female_5_pairs.html 10 guage wire 10 http://www.ebay.com/itm/10-GAUGE-WIRE-10-FT-EA-RED-BLACK-HOOK-UP-AWG-STRANDED-COPPER-PRIMARY-POWER-/271653404495 Anti-spark bullet connector 9 (cause f*** anti spark switches for 60 bux. Such a waste of money cause u can get a bms for less money that BALANCES BATTERIES AND HAS A ON/OFF SWTICH. HEAVY BREATHING Yeah i dont like them) https://www.amazon.com/Amass-AS150-Female-Connector-Battery/dp/B00RVM93YO/ref=pd_nav_hcs_bia_t_3?ie=UTF8&refRID=S5PVG6Y1HD9H3EK2ASGZ blade fuse holder 3.50 https://www.amazon.com/Parts-Express-Water-resistant-Fuse-Holder/dp/B0002KR88A/ref=sr_1_6?s=automotive&ie=UTF8&qid=1467932662&sr=1-6&keywords=blade+fuse+holder 40 amp blade fuse 6 http://www.ebay.com/itm/25-pack-40-Amp-ATC-Fuse-Blade-Style-Scosche-40A-Automotive-Car-Truck-/261404854953?hash=item3cdcf18aa9:g:QT0AAOSwtlhWF~AW 35 amp blade fuse https://www.amazon.com/ATC-BLADE-FUSE-AMP-PCS/dp/B00FK1W0AM Power Analyzer 22 http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=75944 mini voltmeter 6 http://www.ebay.com/itm/Red-0-100V-DC-Mini-Digital-Voltage-Voltmeter-Panel-3-Wire-LED-Display-R07-/151225006526?hash=item2335b679be:g:pvUAAOSwI~VTzlxH 7 pin connector 7 http://www.ebay.com/itm/JST-2-0-PH-7-Pin-Female-Connector-with-Wire-and-Male-Connector-x-10-Sets-/121367876323 4 pin connector 2 http://www.ebay.com/itm/10Sets-XH2-54-4Pin-1007-24AWG-Single-End-15cm-Wire-To-Board-Connector-/182106030475?hash=item2a665d818b:g:9UEAAOSwtPZXHdbZ
Battery Medic 11 http://www.hobbyking.com/hobbyking/store/_10328__HobbyKing_8482_Battery_Medic_System_2S_6S.html
28oz fiberglass 25 https://www.amazon.com/3M-Fiberglass-Resin-Repair-Quart/dp/B000BO7CVK 15 ft velcro 20 http://www.amazon.com/VELCRO-Industrial-Strength-Wide-Black/dp/B00006IC2T
fine wire mesh (ventilation for enclosure) thumb screws wood inserts small hinge
Diagram of my build. Sorry its kinda messy.
UPDATE: Not using 12s anymore but am using 9s cause its safer for the vesc but 8s would more ideal cause there is no chance of going above 60k erpm.As I stated before I am rethinking my battery. I drew a diagram below which I plan to use Samsung 25R cells on so I get 60 amps.
I plan to use this bms which I have heard good things about. http://www.batterysupports.com/44v-48v-504v-12s-60a-12x-36v-lithium-ion-lipolymer-battery-bms-p-270.html ($43) I will use @michaelcpg 's diagram and this helpful vid (seriously a good vid especially for a beginner like me) https://www.youtube.com/watch?v=gnEGYwBa4tk to help me wire my bms. I dont have the money for the batteries right now though (another reason for my slow progress on my board).Plan to buy my batteries for here. http://liionwholesale.com/collections/batteries/products/samsung-inr18650-25r-battery-genuine-tested-20a-2500mah-flat-top-wholesale-lot?variant=1038201992 Its funny that buying 26 cells is only 2 buxs more than buying 24 cells.
