Alright, so I finally finished my board a few months ago and have been riding pretty much every day. I currently have a top speed of about 28 mph, at first I thought this was fast and I didn’t think I’d want to go faster than that. But after getting used to the board and the speed I would like to try to hit somewhere in the 30’s.
Here’s my current setup:
Single FOCBOX VESC
10s5p battery
6364 190kv motor
36T wheel pulley
14T motor pulley
12mm wide belt
90mm flywheels
BLDC Settings:
75 amp motor max
-40 amp motor min
40 amp batt max
-12 amp batt min
Are there any suggestions for settings or hardware to increase my speed?
Well you can go with a 32T wheel pulley, or even 28T, but you will pay for it in low end torque.
What cells are you using? You can make a larger batter(10s6p?) and upgrade to a vesc6 and double you’re amperage. Or, go dual motor and get another focbox and you will also have double the amperage capability.
If you are running 10s5p 30Q, you can put out 80A safely. I would say you could even push it to 100A. You will feel the power difference.
I have 10s5p 30q, so do I need to change the battery amp max to increase the power or the motor max? I am eventually going to upgrade to a dual drive but it’s not currently in the budget. I thought the focbox was the vesc 6 it just had a different name?
Don’t increase battery max to more than 50A on your single focbox. You can only go up to 80A total with dual motors and two foc boxes(40A ea box, or 50A ea box for 100a).
Foc Box is not a vesc6.
Cheapest upgrade would be a 32T pulley, and some 107mm flywheels.
That will be lacking in terms of torque using a 32t on 107s. It can be done though I would recommend changing the motor sprocket as it’s a more direct swap and also cheap as well as the teeth skipping less on braking
I’m with this guy… I find motor pulleys cheaper than wheels… 18/36 was my Fav…but the last 2 single drives I started with left me underwhelmed in performance… And went dual with a quickness… @dickyho has cheap pulleys… Id buy a few for now and future dual and mess with those
I’ll look into going up to 80 a on the motors. I am going to change to a dual build asap, I would really like to use the focbox unity! For now the pulleys seem like the cheapest option! I’m thinking of switching to @Ackmaniac 's firmware cause I think I’d like the wattage control. Any suggestions for that? I know there’s a lot on his original post and I’ve been reading a lot about it!
