Okay. So if you want to make a 12s1p battery with the 37Ah cells, you would need to cut the spotwelded strips and then solder the cells in the right orientation?
Correct, and its not an easy task, as the bus-bars are aluminium. If only they were copper. TIG or MIG welding is the way to to I guess.
Damn it!, was hoping that the connections where copper. Aluminium is a pain to solderā¦
Even a bigger pain to weldā¦
Not if you know what you are doing
Im okay at welding steel, tried to weld my cracked bike frame and had a really ugly time lol nice work!
Thanks. I am a welding engineer so if you need any tips I can give you some.
you clearly donāt!, alcohol free. itās Blasphemy.
Why do you think I punished them by melting their butts off?
I need a new power source for my spot welder, do you maybe have an idea how much amps can they give? Just realized they are 25ah 10c nvm
Hi, i can also get Volkswagen battery modules and I was thinking to use them on My project. What kind of charger and bms you are using with them? Br Thomas
hi charger 8A: https://www.aliexpress.com/item/32824774541.html?spm=a2g0s.9042311.0.0.27424c4ddx02zI
BMS: https://www.aliexpress.com/item/32849341135.html?spm=a2g0s.9042311.0.0.27425c0fRn6NeW
Hello, Iām wondering if these are internally protected, as i have 104 cells that seem to be dead 0V, which seems to be odd for me.
