Here’s what happened: I quickly accelerate to about 10ish mph after a little push (basically full throttle after kick push), then my vesc just cuts power few seconds into hill climb. I started from relatively flat ground, then hill grade increases gradually. If I don’t accelerate too quickly, it can climb that hill at about 15mph without losing power or overheating.
Here’s a video showing the hill (this was recorded a while back). I start at the same spot shown in the video around 2:49, then power cuts off around 2:53
My VESC settings:
FOC mode
Motor max: 60.00 A
Batt max: 40.00 A
Why does it do this?
EDIT:
Fault : FAULT_CODE_ABS_OVER_CURRENT
Current : 214.7
Current filtered : 126.9
Voltage : 31.71
Duty : 0.59
RPM : 33177.3
Tacho : 163671
Cycles running : 29347
TIM duty : 4932
TIM val samp : 5
TIM current samp : 8398
TIM top : 8400
Comm step : 0
Temperature : 38.30
Any recorded faults? When this happens you should keep the board powered on and connect it to a computer and check for faults.
Try with BLDC and check if the same happens, i bet it doesn’t. I had my board shut down when braking and FOC.
Current : 214.7
Voltage : 31.71
Duty : 0.59
RPM : 33177.3
Tacho : 163671
TIM duty : 4932
TIM val samp : 5
TIM top : 8400
Comm step : 0
Temperature : 38.30
@Jinra There’s a Bluetooth module connected to the VESC and a 5v fan connected to the receiver. Will that cause problems? I can accelerate hard on flat ground, but it only shuts down when quickly accelerating into that hill area.
Is there like a problem with my setup? In other words, a short, loose connections, bad settings? Or is it just not capable of what I’m pushing it to do?
